glossy screen much better?
salami1212 said:
does the glossy screen on the nec or the x-black technology make the colours that much better? or is the reflectiveness too bad?
cheers
I would like the answer to this aswell is it much better or is the reflectiveness even worse then a CRT?
It isn't really better or wose, just different' I don't like it because it is so reflective, but the colours look more real and less washed out.
Your best bet is to go into a PC store and have a look.
cheers
yes. it makes a huge difference. the colours look great. as for the reflections its impossible to use if you've got the sun behind you, much like a CRT. But if you dont have an east or west facing window you'll be fine. Mine is North facing and i never have any reflection issues, even at night when i have a bedside light on beside me.
salami1212 said:
is it as bad as a crt?
yes. but it makes the colours look so bright its worth it. As above, unless you've got the sun directly directly on the monitor, you wont notice any reflection.
