Gmail + Outlook 2007 help please?
8 Jun 2006
Hertfordshire
Guys
Bluebottle are going to charge for thier free pop/smtp accounts so I'm moving to gmail.com
Setup Outlook 2007 without issues and I had some mails sync but now I keep getting the box below popping up? Searched and confirmed I have everything set correctly??
Any idea's?
Hi markyb
I followed those instructions before I posted here, I have created 2 accounts now and I cannot login to them via the net as it says the accounts have been disabled??
Is there a contact email address I can mail to and see if they can help me??
Thanks for any help in advance!
Many thanks I have the same issue on a XP Outlook 2003 machine as I do on Vista 64bit Outlook 2007 machine?
Both have Avast installed, looking at that now, thanks
check your inbound server is set to ssl and port 995 and outbound set to tls and port 587
also shouldnt the username be just your username and not the whole address
ie. 'john.smith' not '[email protected]'
Lol thanks I set it up fine via Outlook 2007 automatic yesterday but then things just went from back to worse...
I just want a working email account... Thanks for your help... will keep google'ing it
seems to be an obscure problem somehow related specifically to outlook and how you connect to the internet (work lan, campus intranet), how do you connect?
could try; temporarily at least, either forwarding port 995 to one of the pc's or placing it in the routers dmz just to eliminate that factor - www.portforward.com
have you tried it in another email client (thunderbird?)
Everytime I set the account up client side and send a test mail it appears in google web mail?
I have enabled pop on the settings panel? Is there any other free pop/smtp service I could try?
Thanks
Just a quick update guys, I setup gmail with IMAP enabled and it is now working a treat :D
Thanks to all for your help though ;)
Guys
I added my Gmail account but its second in the tree now (see below) ho do I make it the first primary account, this is the only account I have setup too??
