GMMK Pro
2 Nov 2021
Northampton
Good evening all,
I recently purchased a GMMK Pro from Overclockers UK and for some reason it seems to be defective or the Stabilisers are over lubed as when I press the space bar, it sticks 50% of the time and does not come back up. I hear a squishy noise when I press it so I am going to assume the stabilisers are the cause of my issue. I'm not sure what I should do from here as I do not want to mess with it and affect any warranty etc.
Cheers.
Good evening all,
Cheers.
It's a known issue, all boards are the same, though apparently Glorious have fixed it for recent batches but I've not seen that in the wild?
You can remove the stabilizers and remove some of the excess lube.
It's a barebones keyboard kit so you can open it up and adjust it, that's what it's meant for :)
