Cheers Haircut, that is one way of doing it.
However, I'm sure there is a more "elegant" formula. Probably one that doesn't need to know the years calendar.
I have a computer system that has a clock built in. But the clock doesn't take any account of daylight saving. So what I was hoping for (in an ideal world) is a formula that you can use every time you read the clock to see if there should be an hour added/subtracted etc.
Cheers for the help so far.
Sounds like a waste of CPU cycles!...a formula that you can use every time you read the clock...
