GO Ex Launcher - Locker question
11 Oct 2011
UK
Hi all,
Just installed Go Ex Launcher yesterday (was using Apex before)
I really like the various options you have for the design of the lock screen, however if I unlock my phone screen using the power button, I can then slide the screen down to enter a pin code, BUT if I just press the home button (HTC One X) it diverts round the pin code and doesn't ask for it
Is this a setting I need to change or a problem?
Hope you can help,
EDIT: Same happens if I press the recent apps key, it doesn't need the password for some reason. I've tried a different locker theme too but still the same issue.
2ND EDIT: I used the 'Lock "Home" key' setting and this stopped the home key from avoiding the password, it now doesn't have any effect on the lock screen. However, the recent apps key still has the issue as you can select a recent app (without the PIN) and then use the back key (left of home key) to close the app and then you have basically unlocked the phone without the PIN. Hmmmmm
The home key setting basically makes the home key take you to go locker by default, then if it is unlocked you just see the home screen, but if it is locked you see the lock screen.
Any way I can do the same for the recent apps key?
