Go SLI or upgrade current GPU?
7 Apr 2009
Greenock, Scotland
Hello. So Im kind of stuck on what to do. I have a few options
buy another GTX460 1Gb for SLI which would mean a PSU upgrade also=£200
upgrade to another single GPU=£200
upgrade Mobo+CPU+Ram and keep my current GPU=£400
So is there a GPU I could get for around £200 that is a significent increase over SLIing two GTX460s and would run on my BeQuite 530w PSU?
Thanks for the tips lads but there is no way I can justify spending nearly £300 on a single component
Also my max res is 1920x1080
I picked up a GTX 580 for £170 second hand. It's the going rate now. Can't beat that. Personally i'd try to get something like that and upgrade that PSU as you'll probably need more power eventually not sure 530W is enough for a GTX 580.
See that is my predicament though a 580+ PSU probably about £250
Where as I could get a good Mobo+Ram+CPU for £350?
What's the main purpose of your upgrade? The GTX 580 will run games better than any cpu/mobo/ram combination with a GTX 460. It all need's upgrading tbh what processor are you running with that board? I see it's ddr2 so I'm guessing it's dated.
You could pickup a decent PSU 700W for around £40-50 second hand so if you were to get both at good prices we're talking £210-220.
SLI'ed GTX 460 will perform similar to one GTX 580.
