Hello
How much do you want to spend? Then the rest of us here can give you list of hardware to buy. The most expensive bit would be the Graphics card as they are pretty scarce to buy new at the moment, prices have more or less doubled since the start of last year due to things like cryptocurrency mining, shortages & demand caused by a certain bug etc.
If you want really good value then wait a month or so till the 12400F + B660 combo is out as that should come in under £280 for both then you could put more the towards a stronger GPU.
