God damn "awaiting key authorisation"
Caporegime
30 Jun 2007
Wales
This is ****ing ******* me off now almost every time i try and join a server on COD4 i get that then it buggers up the internet for a few mins (page's wont load) have to close the game and try again till it works on about the third attempt :mad:
I've set connection atempts to 99 while i went to make a sandwich and it still didn't get through. Why can't they put a cancel button on the connect screen/?
This is how mine always is - the best way around it (I found) is to add the servers to your favourites and only show the favourites - instant auth. and join.
Is there a way in COD4 to join a server via its IP address? I cant find anywhere to type it in!
bring down the console with the tilde key (`) then type /connect ip or if the server has a password type /connect ip; password blah
e.g. /connect 85.236.101.99:29360 - dignitas TDM server
/connect 85.17.181.2:28910; password ocuk - for a passworded server
Also has the OP tried typing /reconnect in the console when the key auth issue comes up? This can help recitify the problem :)
Had the same issue. one restart solved it.
I had it for a while, just went away eventually. I think it might be down to your ISP as on 20Mb virgin at uni it takes a lot longer to connect than my 512k at home which is instant
