Ok so going 2Gbit at home. I'm confident this is all right and will work, but as i'm extremely low on funds at the minute I thought it best to confirm with someone else first. In this case, all the wonderful people on the OcUK forum!
Ok so, plan is. . .
Room Bed4 4x Cat5e ports installed.
2 ports - room Liv1
2 ports - room Off1
3x Netgear GS108T-200 switches 1 in each room. Trunked ports to give 2Gbit link to each location.
Virgin Hub linked to Bed4 GS108T switch on 1gbit link. Also ps3.
NAS/HTPC in Liv1 connected to the second GS108T using teamed 1gbit links 2gbit total. Also connected BluRay player, and TV.
Main pc (see sig) in Off1 connected to the last GS108T using a Intel dual port gig card.
So
Bed4 - Liv1 2x 1gbit links trunked 2gbit bandwidth
Bed4 - Off1 2x 1gbit links trunked 2gbit bandwidth
This will all work yes? Nothing to complex, the switch supports link aggression, trunked links etc.
Can someone confirm before I spend £240 on cabling and switches!
Cheers
Ok so, plan is. . .
2 ports - room Liv1
2 ports - room Off1
So
Cheers
