Hi,
My current rig is air cooled and in the past I've had a custom watercooled setup. I don't have any real issues with cooling at the moment but really like the look of all the modern custom watercooling kit, especially the hard plastic tubing.
I know I could opt for an AIO cooler but I really like the idea of putting the gpu under water. Its likely I'll be purchasing a 3070 at some point.
Ideally I would like to use my current case albeit a little small. I like the idea of the reservoir which incorporates the pump.
How loud are the pumps nowadays as the quieter the PC the better?
I also see its quite an art in bending the hard plastic tubing.
Any advice would be great.
