geeza said:Currently have my Opteron 146 running at 2.8ghz with Gskill HZ memory. Would it be worth me getting something like an opteron 170, 175 or X2 3800 or 4XXX?
I really want to stick to socket 939 and not upgrade the lot
geeza said:doesnt that 165 have half the cache of the 175? wont this make a difference?
And if your mobo can't do that, get a 170, as that's got the same multi as you have now. I got mine from the bay too, they usually give you an idea of what stepping you're buying too which is nicejoeyjojo said:9 Multi. 333 htt needed for 3ghz.
geeza said:still £90+ for a second hand 165. what is the multi on the 165? memory is on 254mhz at the moment on 10x multi and a divider
2800mhz
Luffy said:As you can see in my sig I have an Opty 146 and I noticed worse performance in games with an AMD 4200 X2 @2750mhz, even with the dual core patch. Unless you need the X2 for encoding or multiple apps I would stick with the 144.
I've got an 1800XT which I always run at stock and that coupled with my Opty gives a damn good gaming experience. For instance, I know HL2 is CPU limited but how does 200FPS sound?geeza said:interesting. i was thinking on the lines of supreme commander and crysis. Whats this about a new graphics card. Surely wont the next gen games require dual core more than a top end graphics card. my overclocked x1800xt could surely handle graphics on medium/low settings
For next gen games though it's going to be a bit of both I reckon.555BUK said:I went from an Opty 148 @2.9Ghz to a 165 @2.9Ghz. The performance increase and additional smoothness of dual core were well worth the upgrade.
.J.D said:So Geeza. Did my big talk put you off and only just this morning did you go and buy a set of golf clubs and thought to yourself "Sod this PC crap?".You never know. Had to ask
