- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
More PSU greatness with this new 600w 80 Plus Gold PSU for under £70.
To put this is context:-
The Corsair TX 650w is £74.99 and is only 80 Plus Bronze
The XFX 650w Core 80 is £69.98 and is only 80 Plus Bronze
The Antec True Power 650w is £69.98 and is only 80 Plus Bronze
So to get a 600 wattage 92% efficient PSU for the same price must be a great deal in my opinion!
BeQuiet is also a great well known, reliable brand. So the quality will be there. The stock should be here next week.
BeQuiet Efficient Power 600W '80 Plus Gold' Power Supply @ £69.98 inc VAT
The highly efficient '80 Plus Gold' power supply provide a typical 92% efficient unit to reliably and safely power your PC. Whether it is an office machine, a multimedia beast or a monster gaming rig this unit is ideal for all. With four +12V rails this can support all of the latest hardware including 2 GPU's as it has four PCI-Express power connectors and can power up to 6 SATA devices and and 4 molex powered devices.
- 120mm high-quality fan with a reliable silent bearing.
- Active clamp- + SR technology for very efficient and stable operation. Compatible with ATX 12V V2.31 and EPS 12V V2.92.
- Effective continuous output of 600W.
- Four independent 12V rails.
- Supports the latest generations of processors from Intel and AMD.
- Very efficient and power-saving operation
- 80PLUS Gold certification for the highest efficiency of up to 92%.
- ErP Lot 6 ready.
- Power consumption in stand-by mode <0.5W.
- Fulfils the requirements of the Energy Star 5.0 environmental and energy-saving guidelines.
- Suitable for multi-GPU operation: 4x PCI Express (2x 6+2-pin and 2x 6-pin).
- High compatibility with future as well as older components:
- 12V P8 connection (P4+4).
- Top safety and reliability
- Top protection for your components (OCP, OVP, UVP, OPP, OTP and SCP). Certified in accordance with international safety standards.
- Engineering, design and quality control in Germany
- 2-year manufacturer’s warranty
Only £69.98 inc VAT.
ORDER NOW
- ErP Lot 6 ready.
ORDER NOW
