I've got 4x1GB modules of GeIL 2GB (2x1GB) DDR2 PC2-6400C4 800MHz Ultra Low Latency Dual Channel RAM sat in my Asus P5K Vanilla mobo. This stuff, bought it here from the shop a while back:-
http://www.overclockers.co.uk/showproduct.php?prodid=MY-058-GL
I'm looking to squeeze out a last little bit of performance from my current Q6600 based system before I build a new i7 based system later in the year. This will include grabbing a pre-owned 6950 or similar GPU to replace my 9800GTX+. However I'm thinking I may upgrade my RAM as well, to 8GB from my current 4GB. The P5K supports a max of 8GB and only 2GB per slot so I'm looking to obtain 4x 2GB modules of memory. The current 4GB of RAM will end up in my wife's PC as she is sat with 2GB on an old Asrock 945G E6300 based system which she uses for basic tasks.
My question is this - Will I notice a difference if I upgrade from 4GB to 8GB? The most demanding tasks it gets asked to perform are the odd game now and again (currently playing Arma III
) as well as Photoshop, Fireworks and Illustrator related work.
Ta.
Ta.
