Hello. So I recently bought another GTX460 to go SLi. Im actually happy with it for the most part but as usual heat is my enemy. Now I have been thinking of going single GPU but I dont know what card to get that would be comparable/better than my SLi GTX460's.
I have the 1gb models so I would definitely be looking foe a 2gb card. Budget under £200 but I would consider a second hand card. Nvidia or AMD.
The rig you see in my sig will be updated soon to
Asus Maximus IV Gene-Z/Gen3
8gb G Skill RipJawX
i5 3570k
Thanks
8gb G Skill RipJawX
i5 3570k
Thanks
