Going Old-Skool
28 Jan 2011
Hey guys,
I just ordered a "trash can" Mac Pro. Will the Arctis Pro Wireless work with the mac? I ask as when I see specs it does say, PS, PC, AUX etc..
Cheers.
Are you OK using them via bluetooth (downside being minor delay)? If so, yes, they'll work. If not, depends on whether the 2.4ghz dongle is compatible with the version of macOS you install
yeah, i have decided to sell the headphones, as they are ideal for gaming, but this will be for non-gaming so wil use BT on my B&W headphones.
Cheers for the replies.
