Going on holiday next week, what to do to stop car battery?
29 Aug 2011
UK
Hey guys, going on holiday next week for about a month, my car will idle is there any way to stop the battery from going flat. Because that is what happened last time round. Cheers
You can get solar trickle chargers that plug into the cigarette lighter and sit on the dash. Unless it is garaged of course.
Andi.
Are you driving the car to the airport and parking it up, or leaving the car at home? If taking to the airport, take a 10mm spanner and disconnect the battery after you've parked, or buy a cheap jump pack? If left at home then either do the same or a small trickle charge
What car is it? Most should be able to survive a couple of months without going totally flat.
A month? Nothing.
I left my car in Luton airport car park from mid October to mid January and it was fine.
Then I left it in Heathrow from March until mid July, and it was still fine.
Replace the battery if it doesn't hold charge or figure out what's draining it would be my thoughts.
The wife's 8 year old Mini was left on the driveway for 6 weeks and started first time. Just had to clean the spiders out of the wing mirrors!
Appreciate the responses guys, well I have left it now as I'm on holiday now. It does have the rac battery fitted and has 5 warranty. And had them replace it 3 months ago because of that heat in the summer. So I hope it will be fine when I get back.
So came back today battery totally dead(my dads car battery is fine though), what now I have changed the breakdown which actually starts today with green flag. will they replace battery if I give them a call out?
Thanks
Thanks
I’d call them and ask, when you say it starts today do you mean you’ve just taken it out today or previously?
Why didn’t you just disconnect the battery anyway?
I've taken a new breakdown cover with Green Flag which starts today, not with RAC anymore. I guess im not confident enough to do it lol(car noob).
A breakdown company will just jump start the car for you.
It sounds like you have a current drain somewhere. Depending on how bad it is you could just leave it and disconnect the battery when you know you won't be using the car for a while.
Agree, if the OP had a new battery fitted 3 months ago it shouldn't have gone flat so quickly.
I'd disconnect it next time you plan on leaving the car for more than a couple of weeks
