Going sideways...
AFAIK, this one is the cheapest on OCUK. Its not exactly cheap, but for your money you do get an excellent screen with a high qulaity IPS panel. If you want to spend less, they you may want to have a look at some of the cheaper dells (with similar stands to the U2211H one) , but are not currently stocked by OCUK.
Also, you could go for a cheap monitor which is VESA compatible and buy a third party monitor stand/arm which pivots to portrait mode.
