I'm using adobe illustrator and when my artboard gets big memory becomes an issue, even with two gigs of 3200 OCZ mem in dual chennel mode.
(my current OCZ el 3200 memory is running at 2.5-3-5-3 it took me few months to figure out that running it at 2-3-5-3 "which is what its advertised at" would cause HL2DM to lock up and fail in mem test.) is there much difference between 2.5 and 2 ? did I do the right thing ? right now its finally rock solid, but I want more memory.
If I add another two gigs(which is v cheap at the moment), will there be any performace related drawbacks. ? am I ok with windows xp pro?
all of this would be running of a DFI-SLI-DR board with plenty of juice from a seasonic s12.
thanks muchly for guidance and thoughts.
larz
larz
