Going to a race, advice needed!
19 Sep 2010
The North
I'll be off to watch the BTCC touring cars at the start of June at Oulton Park, and would love to use the weekend as a chance to try some new photography. Until now the only thing I've really tried is landscapes, scenery and portraits and as such only currently have 2 lenses.
I assume I'd be best renting a lens for the weekend, but I'd ideally like to save as much cash (and weight!) as possible there.
Current equipment is a Canon 30D, with a 50mm 1.8 and 18-55mm IS, so as you can see no long range lenses. THIS lens has tempted me due to its compact size for a 300mm, and I don't mind doing a bit of PP to tidy up the images. However, the aperture seems to be its flaw.
To that end, I'm also curious what sort of focal length I should be looking for, remembering the 30D is a crop sensor. 400mm feels like it might be excessive?
Why not just pick up a Tamron/Sigma 70-300mm from a shop? Same apertures and less quality but it's not much more and you get to keep it.
A 70-300mm should work well for racing, the tricky bit is getting somewhere where you can get the shots from!
Im using a 70-200 f4 IS at Donington BTCC next week. Should be enough I hope on a crop body (500D).
The only other lens ill be taking is the 18-55m IS kit lens. Even so I probably wont use it as I dont like doing lens changes in the open.
I wouldn't really worry too much about the maximum aperture. If it's a nice sunny day, which it should be, then you won't have to worry about adjusting the aperture to get a fast shutter speed.
And if you're panning, you don't need a very large aperture anyway.
I went to donnington a few weeks a go to watch the world superbikes armed with a 70-300 lens & found I was using the max length everywhere on the track other than the foggerty esses and even then I still needed around 250. If your going on the race day (sunday) I would advise getting their early as it really does get busy and you will struggle to get a spot to shoot at 200mm. I am actually going to watch BTCC on the 17th
The maximum you'll need at Oulton is ~200mm. Always worked well for me :)
I think the BTCC is one of the ones I'm at this year too!
I've always found 200mm to work quite well with motorsport.
The 70-300mm tamron lens is pretty poor btw, my dad has it and I've not been that impressed tbh.
I don't know if we're talking about the same lens here but the Tamron 70-300mm f4-5.6 SP Di VC USD Lens is a cracking lens, Unbeatable for the money imo. it can be had for around the £350 mark
Cool, may see you there. Never been to Donington before so will be a new test.
Didnt think it got as busy as the superbikes. Every time I watch the btcc on TV its not that packed. Looks fairly relaxed.
70 - 200 works fine for me at Oulton Park. There are several places where you can get close to the action.
I was considering renting the Canon 70-300mm f/4.5-5.6 DO IS USM for the weekend, would cost around £50 for 3 days. I know it wont be as good as the L series lenses, but the weight and size of the DO lens make it appeal to me.
It's either that, or the Canon EF 70-200mm f/4 L IS USM / Canon EF 70-200mm f/2.8 L USM, which are actually marginally cheaper. It seems from reading the replies that 200mm is fine on a crop sensor for Oulton.
Any opinions either way?
Got a 70-200 f4 for 400 quid second hand with case and cap, should work out cheaper than renting, hopefully. If I enjoy it, I didn't waste money renting first, if I don't enjoy it I sell it again for 400 ;)
I use a Sigma 70-300 which seems ok for motorsports. It tends to loose a bit of definition at 300mm but I rarely use it at the maximum anyway. Just set the camera to shutter priority mode and experiment :)
Sigma 70-200 f/2.8 - and as it happens I have one for sale in the MM. :p
Seriously though, any of the 70-200 2.8s are ideal, long enough for the club/national circuits (apart from brands), sharp with a 1.4x TC, fast AF with the f/2.8, there all HSM/USM, they all have enough speed to separate a car from track.
