Hi all im totally new to all this but i am going to build me a gaming pc.
My budget is around £570 To fit the budget this is what i have come up with.
Powercolor ATI Radeon HD 4870 512MB GDDR5 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail
Microsoft Windows XP Home Edition SP3 - OEM
Abit IP35 Pro XE Intel P35 (Socket 775) PCI-Express DDR2 Motherboard
Intel Pentium Dual-Core E5200 "LGA775 Core 2" 2.50GHz (800FSB) - Retail
OCZ ModXStream Pro 500w Silent SLI Ready ATX2 Modular Power Supply
Samsung SpinPoint F1 320GB SATA-II 16MB Cache - OEM
Coolermaster Elite 335 Case - Black (No PSU
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket LGA775)
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 X2(4GB)
Samsung SH-S223F/BEBE 22x DVD±RW SATA Dual Layer ReWriter (Black) - OEM
Akasa AK-191-BL Blue Ultra Quiet 120mm Fan - 3 Pin
Just hits the budget.
Is this all compatible.I will be doing some OC with the E5200.
Any help would be greatly appreciated.I could stretch to £600 if a component was really worth it and make a big difference to the system.
Thanks all
Thanks all
