Going to do a fresh install
1 May 2012
Scotland
Going to do this tonight chaps.
I have all original driver cd's from everything in my Sig.
Does anyone have any particular orders you would install the drivers and if so for whatever reason what would you not install?
Would like to do this as cleanly as possible and not put anything on which would cause issues.
doesn't really matter which order you install the drivers in, I tend to do GPU drivers to sort out the screen size and then the rest of them
I normally ensure LAN is my first one then Windows Update to install most of the others. Chipset drivers I normally find occasionally troublesome so it's nice to do them to. Everything else normally gets captured by Windows Update.
M.
Done so far guys all I have downloaded is LAN drivers and AMD drivers for GPU.
Windows update seems to have caught the rest.
