Going to go 2nd hand, but what to get?
8 Jul 2005
I am looking on getting a mobo.cpu and ram from the MM but not sure what to look for. I am going from a 939 setup so anything is an imrprovement.
i think i want AMD as thats cheaper (?)
i think i want ddr3 as that appears to be slightly cheaper than ddr2
what i am really stumped by is the cpu choice.
It would be for light gaming on a 720 plasma so wouldnt need to be massive resolution. It would be partnered with a geforce 9800gtx,
Looking to try to get all 3 for under £100
Any pointers welcome.
You could probably get:
Q6600
Asus 775 Mobo
4GB DDR2
(very few 775 mobo's support DDR3)
for about £120, you might be able to pick it up for 100 though!
Alternatively:
YOUR BASKET
1 x Gigabyte G41MT-S2P Intel G41 (Socket 775) DDR3 Motherboard £38.99
1 x Kingston HyperX Genesis Grey 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/4GX) £19.98
Total : £69.47 (includes shipping : £8.75).
and a lower end Q6600 (not a proven clocker) for £40 (subtract cost of shipping)
kd
