Going to i37? Need a challenge? Want to Overclock my PC
5 Nov 2007
As above really, £50 and a few beers if an overclocking champion can get my rig stable at i37
OCZ Platinum 4GB (2x2GB) DDR3 PC3-10666C7 1333MHz Dual Channel (OCZ3P13334GK)
Asus Striker II Extreme
Q6600 Kentsfield - afaik
All water cooled and 1GW PSU but still cant get it stable at 3gig
Will be on the early arrival service, so should have time to tinker.
Fingers x
Sunburn
Pardon? I've no idea what any of that post means. What do you mean by stable at i37?
It's water cooled? What with and what temperatures?
You don't have a GW psu. You might have a kW one, but all that would tell us is you spent far too much on it or bought a cheap 1kw one instead of a good 600W like you should have. What's the full specification? It quite matters which processor it is
someone sitting next to me at i37 will probably be able to do it, he offered to overclock my new i7 so i presume he can do the older c2ds. Pm me your seat number or something and we'll come visit you :D
I thought it made perfect sense.
He wants someone who is attending I37 and has some spare time to help overclock his rig (which he is obviously taking to the lan) in exchange for some cash.
Yeah was a typo as i was leaving work in a rush :~)
psu is 1KW Enermax Gallaxy
CPUID CPU Name Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
CPUID Manufacturer GenuineIntel
CPUID Revision 000006FBh
HTT / CMP Units 0 / 4
IA Brand ID 00h (Unknown)
Microcode Update Revision B6
Platform ID 29h / MC 10h (LGA775)
Tjmax Temperature 100 °C (212 °F
temps... using core temp....,
low - 33'c 38'c 33'c 35'c
avg - 46'c 49'c 47,c 47,
high - 54'c 56'c 55'c 57'c
Water Cooled with.....
360 Rad, very good pump and stock fusion block water cooling system on NB and SB
I hope this info helps some more..
System:
Motherboard:
CPU Type QuadCore Intel Core 2 Quad Q6600, 3000 MHz (9 x 333)
Motherboard Name Asus Striker II Extreme (2 PCI, 2 PCI-E x1, 3 PCI-E x16, Audio, Dual Gigabit LAN, IEEE-1394)
Motherboard Chipset nVIDIA nForce 790i Ultra SLI
System Memory 4096 MB (DDR3-1333 DDR3 SDRAM)
DIMM3: OCZ XTC Platinum OCZ3P13332G 2 GB DDR3-1333 DDR3 SDRAM (7-7-7-20 @ 666 MHz) (6-6-6-18 @ 571 MHz) (5-5-5-15 @ 476 MHz)
DIMM4: OCZ XTC Platinum OCZ3P13332G 2 GB DDR3-1333 DDR3 SDRAM (7-7-7-20 @ 666 MHz) (6-6-6-18 @ 571 MHz) (5-5-5-15 @ 476 MHz)
BIOS Type Award (10/07/08)
Display:
Video Adapter ATI Radeon HD 4870 X2 (1024 MB)
Monitor Dell 2405FPW (Digital) [24" LCD] (M675456T054S)
Multimedia:
Audio Adapter ATI Radeon HDMI @ ATI RV770 - High Definition Audio Controller
Audio Adapter Creative SB X-Fi Fatal1ty Sound Card
Storage:
IDE Controller NVIDIA nForce Serial ATA Controller
IDE Controller Standard Dual Channel PCI IDE Controller
Storage Controller APJT566I IDE Controller
Storage Controller Microsoft iSCSI Initiator
Floppy Drive Floppy disk drive
Disk Drive Maxtor 6 L300S0 SCSI Disk Device (300 GB, 7200 RPM, SATA)
Disk Drive Maxtor 7 B300S0 SCSI Disk Device (300 GB, 7200 RPM, SATA)
Disk Drive SMSC 223 U HS-CF USB Device
Disk Drive SMSC 223 U HS-MS USB Device
Disk Drive SMSC 223 U HS-SD/MMC USB Device
Disk Drive SMSC 223 U HS-SM USB Device
Disk Drive WDC WD15 00ADFD-00NLR SCSI Disk Device (150 GB, 10000 RPM, SATA)
Optical Drive PLEXTOR DVDR PX-708A ATA Device (DVD+RW:8x/4x, DVD-RW:4x/2x, DVD-ROM:12x, CD:40x/24x/40x DVD+RW/DVD-RW)
