Going to install win xp pro (again)
4 Jan 2004
I've usually just stuck the disc in lads and lasses and done a basic instal with no partition size etc but I've decided to do a clean install and partition my drives as I've been told this improves performance.
I have a wee 160 gig hard drive and would like to know what size of partition I should create when doing my install. Are there any other details you need to know before offering me any advice?
Many many thanks in advance
Al;)
Thanks for the speedy reply siumatfung;) To be honest I hardly play games on the pc and the applications I would install are just antivirus,spyware etc.
I was gonna install BF2 again (not played that for ages) and the odd flight sim so I wasn't sure if I should create a seperate partition for games etc.
I have 2 gig of ram if that makes any difference too.
Thanks again
Al:)
I've got an AMD Athlon 64 3700 (SanDiago I think it is) processor (2.4ghz) with the 2gb of RAM, 160gb hard drive, Audigy 2 zs sound card and an old 7800 GTX graphics card all stuck on to an Asus A8N SLI premium m/b.
Just found my old W/D 250gb external hard drive too but my pc isn't recognising it for some reason:(
Al:)
Thanks again for your help:D
The only improvement putting your OS on a small partition on the same physical device does is speed up maintenance tasks. (error checks, defrag).
Splitting a physical drive into partitions does not increase performance. It will actually slow you down. Albeit only by a small degree.
You've been listening to bad advice.
im sorry but there was no mention of it increasing speeds at.
i advised him to get more ram :D
anyways he may not have to partition it now he has found a 250Gb HDD:D
bad advice why thankyou
I'm responding to his first post. This is why I quoted it.
I made no mention of whatever you have posted. This is how quotes and flat forums work.
