Going to photograph some a live volcano.. Help!
25 Oct 2002
Derbyshire
In 3 weeks i'm off off to Stromboli on the northern coast of Sicily.
I want to get a shot like this or better... :p
Exposure 20
Aperture f/8.0
Focal Length 175 mm
Focal Length 174.5 mm
ISO Speed 200
no exif
I'm taking the tripod and Canon 30D but think I'm gona need a new zoom lens, my old siggy is sick and not worth the repair..
I've looked at the canon 18-200 IS, tamron 18-270 and siggy 18-200 (i think).
All seem much of a muchness in that bracket.. I'm looking at 2nd hand.
Has anyone done it and have any tips? Has anyone got any comments on the lens options?
The Tamron 18-270 is a pretty good lens for an all-in-one solution for walkabout, it's compact and relatively lightweight, the only downside is it's a bit stiff around the 200mm mark. The stabilisation is better than some of the other brands too if that makes any differences to you.
i would recommend the canon 70-200mm l f/4 IS it a very good lens plus a nd4 grad filter
update: had little more time to think. a nd filter with a Polarizing filter should help as the nd will allow for increase exposure time and the Polarizing filters when used correctly will cut down on any unwanted glare & reflections. now as you going to be some distance from the target a focal lengths between 200-300mm should do the trick. plus a remote shutter cable.
I don't think reflections and exposure length is going to be an issue tbh. To get that type of shot you're looking at shooting at night so exposure length isn't really an issue. An ND filter may be of use on occasion though. OP I think you should look up a couple of star trail tutorials as it will use a very similar technique. I've only managed to shoot them from a distance and used a 12-24mm lens for some shots of the volcano against the night sky then a 75-300 to get a closer view of the flows.
A good sturdy tripod will be essential and as I mentioned before read up on shooting star trails, it will give you a good grounding.
I'm jealous, not least because I'm current within visible distance of one of the most active volcanoes in the world, except it's been dormant for the last two years, nothing but a puff of steam!
Call me ignorant, but where do you live? :)
Thanks guys!
Don't think i'd get the use out of the 70-200 :( I travel light and that would take too much room up.
I've gone for the Tamron 18-270mm, if i don't like it it's back on the bay :)
Thanks guys!
Have a great trip, looks like you will be in for a spectacular sight!
Live? Hertfordshire. I'm currently on holiday though so not there!
Thanks guys!
The 70-200 really isn't that big, although a single lens is something that can be mighty useful when travelling and not having much time to get a shot (as the last two weeks can attest). You will however get much better image quality out of the 70-200. I'm guessing the long end of the Tamron will be rather poor?
