going to try and upgrade
27 Mar 2013
Hi all, I am still new to the world of pc gaming and over the last year have managed to build up my pc. However I now want to upgrade to win 8.1 and have no idea what will happen. Will I lose all my games etc installed on my hard drive? Also what about my recent Kaspersky2014 upgrade, will I lose the programme as it was a download? I would appreciate any help thanks.
Well, it's a supported upgrade path, the simplest way to check what software might need reinstalling is to run the Upgrade Assistant - http://go.microsoft.com/fwlink/p/?LinkId=261871
You'll probably find that some things need a reinstall, some might not be compatible (although that's unlikely), and most will just happily stay as they are and continue to work in Windows 8.1
Thanks I will do that. If I had to re download steam and origin will I have to buy games again or will they just be registered to my account and downloable again? Cheers.
Registered to your account. You can download them as many times as you want though some may have copy protection which limits the activations (though I wouldn't worry about this personally).
M.
M.
Thanks very much, thought that was the case, well hoped anyway.
