Today I just received my second 6800 GT, made by leadtek, decided I'm going to have a play with SLI, but the question is, will it run ok with my current xfx 6800 gt ?? Or do they both need to be from the same maker for SLI to work ??
benjo said:Bit silly asking after you bought it?But not to worry, because afaik you can mix/match brands as long as they are the same core/board
MeatLoaf said:Should be fine as later drivers allowed SLI with different vendors as long as they both have the same core.
easyrider said:Not really worth two 6800 GT in SLI.
would have been better to get a 7900 GT instead.
Behemoth said:Sadly I don't have big pockets like some people do on here, so I have to comprimise with older kit.
