Hey. This is my first attempt, so I'm aiming to keep it simple. Only putting an 8800gt underwater for this loop, would like a reservoir since I think this will make my life a bit easier.
Intended plan is reservoir -> pump -> rad -> card though I doubt the order of rad and card matters. I'll probably be using 11/8mm tubing as the gpu block has compression fittings for this size.
The radiator I'm looking at is the quiet power swiftech 120.1, any guesses how well this will do at cooling the gpu? It'll have a 1600rpm scythe s-flex pushing air through it from the outside of the case but will be mounted internally [I assume case : fan : radiator but know nothing about shrouds]
I'm concerned about the 3/8" barbs fitted to the rad as I would have liked compression fittings, and I'm not convinced by fitting 11/8mm tubing onto 3/8" using clamps. Reckon I'll be alright here or would moving to 3/8" tube be a much better call?
Finally, I've seen this http://www.overclockers.co.uk/showproduct.php?prodid=WC-007-XS
which is a combined bay res and pump at 25 quid. This is very cheap, so presumably quite rubbish, but will it cope reliably and effectively with an 8800gt and a radiator?
I'd very much appreciate any input, a part of me is still screaming that water and electricity should be distant
Jon
Jon
