Going wireless with Virgin Broadband?
24 Feb 2003
Porthcawl and Southampton
Mate has a virgin tv/phone/internet package. The coaxial cable goes into his proprietary modem and a standard network cable out carries the BB.
He wants to go wireless. I see the options as either plugging the existing cable in to a router/switch which sends it wireless.
OR a specific "cable router" that takes the cable from the wall and sends it wireless like this
http://www.overclockers.co.uk/showproduct.php?prodid=NW-012-BE&groupid=46&catid=1014&subcat=
Anybody been through this that can recommend a product for his use? I've never had cable so find it hard to advise him :)
all that is is a router designed to work with a cable modem
for that hardware to work he will need to use both the virgin modem and that belkin router.
cable from wall> virgin modem> CAT5 cable> router and go from there
It needs to be marked as: "DSL/cable router" or "broadband router" or "cable router" - it can't be a "DSL Router", because you need the RJ-45 input for the broadband, rather than the smaller, RJ-11 as is used for a DSL connection.
