Gold, Platinum & Titanium low wattage psus.
8 Jan 2010
Hi all,
Just received my Superflower Golden Green 350w psu.
Very happy to see it has 2 x 6/8 pin pci-e connectors for my old 680 gpu.
Building a low wattage mini itx build and no longer need massive wattage psu.
Cannot find any reviews for this new model, the original one had just one pci-e.
FSP did make a 400w Platinum psu last year but have not yet seen it in retail.
Will OCUK be stocking anything like this in the future?
Has anyone seen anything higher than Gold in the 400w and under range?
Sadly OCUK is lacking in small capacity quality psu's and seem to concentrate on higher capacities.
The FSP unit was cancelled for some reason. They do have Gold units down to 250w but good luck trying to find them on sale. There's the Platinum Aurum 92+ 450w but that's as low as that range goes. Seasonic has a 400w platinum fanless unit. No doubt it's silly expensive though.
Are you sure that 350w is enough? Reviews of the 680 conflict each other with some giving total system power consumption in the 250-300w range and others in the 300-370w range.
Just to give you a heads up, it's not that we don't want to provide lower wattage Gold/Platinum rated units, its just that in most cases it's not economically viable for the factories to produce these units. Having said that, we're offering 350W Gold units from SuperFlower and Seasonic, who happen to be the top 2 PSU manufacturers in the world. I'm working on getting some modular options available around this wattage too :)
