Hi, I have a golf mk2 gti 16v. Just hoping that someone on here has some idea whats wrong with it. Its done 124k without a rebuild so its obviously due for something to go pop.
Usually on a cold morning it will start up on 3 cylinders and then the forth one will kick in with a few revs. But the other day I started it after giving it a little service (plugs, leads, dizzy cap etc.) it was running rough and started chucking white smoke out of the exhaust. After driving it around the block this went away. Was behaving for a few days then yesterday as I was driving it lost power and white smoke appeared again.
I have illiminated the ignition, swapped all the bits back over to the old ones and still the same problem. By pulling the leads out as it was running I found that the 4th cylinder wasnt firing although the lead was sparking and the plug from that clyinder was wet with petrol, tried swapping the plugs with the same result.
So the white/grey smoke must be the unburnt petrol?
So what do you think it is likely to be? Head gasket or something?
Thanks for any help you can give.
