golf problems help please vag-com errors
31 Dec 2002
on my PC
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,16,15,17,19,22,35,46,56
Address 01: Engine
Controller: 06A 906 018 CG
Component: 1.8L R4/5VT MOTR HS D02
Coding: 04000
Shop #: WSC 00000
5 Faults Found:
01249 - Fuel Injector for Cylinder 1 (N30)
29-10 - Short to Ground - Intermittent
01250 - Fuel Injector for Cylinder 2 (N31)
01251 - Fuel Injector for Cylinder 3 (N32)
01252 - Fuel Injector for Cylinder 4 (N33)
01247 - Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80)
26-10 - Output Open - Intermittent
Readiness: N/A
Address 03: ABS Brakes
Controller: 1J0 907 379 Q
Component: ABS/EDS 20 IE CAN 0001
Coding: 13504
Shop #: WSC 01317
No fault code found.
Address 08: Auto HVAC
Controller: 3B2 907 044 C
Component: CLIMATRONIC C 0.7.0
Coding: 01000
Shop #: WSC 01317
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 1J0 920 921 A
Component: KOMBI+WEGFAHRS. BOO V28
Coding: 05442
Shop #: WSC 00000
Ident.-Nr. WEGFAHRS.:VWZ6Z0Y1626273
Address 19: CAN Gateway
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 01317
Address 46: Central Conv.
Controller: 1J0 959 799 AH
Component: 4V Zentral-SG Komf. 0001
Coding: 00256
Shop #: WSC 01317
1 Fault Found:
01135 - Interior Monitoring Sensors
36-10 - Open Circuit - Intermittent
End --------------------------------------------------------------------------------------------------
any one help?
well it seems like it runs fine cant see any real diffrence, it does judder a bit some times. so not sure what to do.
