Got the stuff in my sig. Along with
asus a8v deluxe rev 2
So if i put my
CPU volts to 1.5
Mem divider ddr 333
HT 4x
ram volts 2.8
(not sure what multiplier to use) probably 10 or 9x
Then all i do is up the fsb about 5/10 per test till it becomes unstable?
About ram stuff can i leave it with tight timings (geil value 2gb ddr400 dual channel kit) (2.5,3,3,7 1T) Or do i have to put it back to stock?
Thanks.
Whats the chances somit can go wrong and if so what? I really dont fancy installing windows again if it gets corrupt. My aim for the oc is to push my amd 3500+ venice (E6) from 2.2ghz to something that will be good for my gfx card the HIS AGP 512mb x1950pro. So something like 2.5/2.6ghz?
Last time i overclocked tho i did get 2.5 once but had bios problems as in everytime i tryed to enter the bios, the computer froze. Was sheer luck that i could reset it without doing the cmos jumper. Had to redo all bios settings again which sucked.
So if i put my
CPU volts to 1.5
Mem divider ddr 333
HT 4x
ram volts 2.8
Thanks.
