So I done a post the other day about a new router a bought. I’ve been looking into it since and I’m currently with Virgin 350mb 3.0 hub, which is a dual band router.
The current router is D-Link AX100 and the reason for the purchase was to help out my poor ring devices that struggled with signal strength with the VM hub. This has been tested in a more central place in my home and works 10x better, it works just as well where its currently placed. I was thinking for me to offload some of the WiFi devices it means I’ve got to do a lot of drilling and cable management to get them to the new placed router via Ethernet.
So I’m thinking should I upgrade to tri band? Is it worth it for me, is this going to be over kill? I’m thinking it would it be easier just to get a mesh router such as a Linksys MR8300 with an additional node like the WHW0301? That way I can offload about 4 WiFi devices directly to the router then let the rest use WiFi.
I’ve got 12 devices total at this moment running of the routers WiFi, except for one which is Hive. The others consist of 4 ring devices, Alexa, robotic hoover, Apple TV, my iPhone, harmony huh and 2 unknown devices.
Have I gone to far thinking this through, is there a much simpler setup, so I need a slap to the face?
