- 27 Jan 2008
The spec is as follows:
Case: Antac Sonata III (with Earthwatts 500w PSU)
Mobo: Gigabyte P35C-DS3R (supports 45nm)
CPU: Intel Core 2 Duo E8400 (Penryn)
RAM: Corsair 2GB DDR2 6400CS Twinx (2x1GB)
GPU: Asus Geforce EN8800GT
HDD: 2 x Western Digital RAID Edition 160GB SATA II 16mb cache - in a RAID 0 set up.
Optical Drive: Samsung SH-S202HBEBN 20x DVD rw IDE
Sound: Onboard
OS: Existing XP SP2
Monitor: Asus VW1935 19" Widescreen.
I can source all this from various suppliers for around £660.
I was looking at getting vista 64bit and 4 gig of RAM but i have heard that the SP1 for Vista is still easily outperformed by SP3 for XP, according to beta tests.
I want this primarily for playing games, specifically AoC, although i am not expecting uber high resolution and performance or DX10.
Not sure wether to get this now or wait until Funcom guarentee no further delays closer to May.
Do you think there will be price drops in the key items between now and then, as i have heard that the geforce 9000 series are on their way.
And finally i have read the post about building the rig, but the thing i am unsure of is what i do after it is all put together and powered up (if it works ^^) do i stick in my OS disk and install it or do i need to do stuff to the mobo bios first or something else?
Anyway all comments much appreciated.
Sound: Onboard
OS: Existing XP SP2
