Good ADSL modem usb
27 Jan 2005
Letchworth Herts uk
Hi there what is a good make of ADSL modem usb ? i want it to work with Vista when they release the drivers ..thanks :confused:
A network cable, surprisingly enough.
It works like your USB modem, except instead of a USB cable you use a network cable and everything goes via the router.
thsx
Rhanks ,so the network cable fits into where ? from the Router to what socket on the p.c ? :confused:
Network card if there is one, most mobos have them as standard nowadays built in, ore get a pci network card for a few quid.
