Good air cooled case
12 Feb 2010
im using a Silverstone Raven RV01 right now and its not too good for air flow for my setup the case is suited more towards water cooling anyway can anyone recommend a good air cooled case budget is £200
_____________________
Gigabyte X58 UD5
i7 920 3.4ghz
Noctua NH-U12PSE
6GB Patriot Viper 1600mhz
XFX HD5970 BE
750w Be quiet dark power pro
im aiming more towards a larger tower to house my 5970 been looking at a few cases but cant decide
Gigabyte X58 UD5
i7 920 3.4ghz going to 4
Noctua NH-U12PSE
XFX HD5970 BE
been looking at the antec 1200 obsidian 800D and the HAF 932 not too fond of the Haf though dont like the silver interior and theres no dust filters at all on the case
Gigabyte X58 UD5
Noctua NH-U12PSE
XFX HD5970 BE
its a nice case but i would prefer something that has a side window other than that looks like a great case for its features
___________________
Gigabyte X58 UD5
i7 920 3.4ghz
Noctua NH-U12PSE
XFX HD5970 BE
There is an optional side panel with a window :)
were do you purchase the optional side panel window
Gigabyte X58 UD5
i7 920 3.4ghz
Noctua NH-U12PSE
XFX HD5970 BE
there are so many good cases its hard to chose what lol im also trying to get my hands on a Noctua NH-D14 to replace my current Noctua cooler but cant find them anywere all iv seen them on is another website with no ETA would be nice if overclockers had some in stock
Gigabyte X58 UD5
i7 920 3.4ghz
Noctua NH-U12PSE
XFX HD5970 BE
nothing realy i was going to check what the temp difference would be at 4ghz on my 920 between the two coolers
Gigabyte X58 UD5
i7 920 3.4ghz
Noctua NH-U12PSE
XFX HD5970 BE
think i might get the antec 1200 is a very good case at a reasonable price although i think the 5970 makes one of the hard drive cages unusable
___________________
Gigabyte X58 UD5
i7 920 3.4ghz
Noctua NH-U12PSE
XFX HD5970 BE
thats actually a big drop in temps. didnt think it would be by that much
___________________
Gigabyte X58 UD5
i7 920 3.4ghz
Noctua NH-U12PSE
XFX HD5970 BE
im going to go with the antec 1200 prefer the black interior and the Haf 932 dont have any filters at all so it would get a lot of dust building up inside i'll be ordering the antec this week or next and i'll try to get a Noctua NH-D14 as well
Gigabyte X58 UD5
i7 920 3.4ghz
Noctua NH-U12PSE
XFX HD5970 BE
thnx for the advice ppl
Gigabyte X58 UD5
i7 920 3.4ghz
Noctua NH-U12PSE
XFX HD5970 BE
