Good Case for Watercooling
17 Sep 2010
Wolverhampton
Hi Guys,
I need a good case for watercooling, it will have the system in my sig but without the H50 :) oh and it also needs to have a window :)
Any suggestions?
The TJ07 isn't actually that great for water cooling out of the box - it needs some modding.
Yup. Though you can get them pre-modded from some er...alternative retailers.
Just saw the new XSPC H1/H2....they look amazing!!! Cheaper than importing a mountainmods case too.
Much prefer the look of the TJ07 over the obsidian though.
If you're installing just a single WC loop and want a triple rad in the bottom, then I didn't think the TJ07 required any modding, I believe a quad rad requires removal of the lower drive bays but a triple should fit straight in, drive bays an' all.
FT01BW - I'v owned one for 2yrs and l never get tired of it, have had plenty of nice comments of my freinds who are into PC's because of its curves, easy to work on. The rad mounts on the back of the rear of the case, no problems at all. :)
My case scroll down to you see my name OLDPHART -
http://forums.overclockers.co.uk/showthread.php?t=17305236&page=22
FTO1BW - Case -
http://www.overclockers.co.uk/showproduct.php?prodid=CA-055-SV&groupid=701&catid=7&subcat=
It isn't what one would describe as a 'watercooling case' though? As nice as it is, I think when most ask for a watercooling case, they mean all internal, as almost any case can have an external radiator hung outside.
800D, 700D, TJ07, V2000 would be the most obvious cases to spring to mind that aren't stupidly expensive, and require minimal modding.
