Good Cooling Case
17 Sep 2010
Wolverhampton
Hi All,
Im looking for a good case to cool the spec in my sig (my 480 being the culprit og high temps idling around 44-48C) Im looking to spend around £50 - £70 maybe push it a bit further, anyone suggest anything?
Thanks,
cheaper option - Zalman Z9 Plus
or ARC Midi for about £75 - you can remove top hdd cage so fan will blow directly towards GPU and add a bottom fan if you really need to
