Good Cooling/Size Case, CM690?
9 Sep 2009
What are people's thoughts on the CM690 for Cooling and Space/Size? would there be a better alternative for around £100 budget. I was thinking if the CM690 was packed out with enough 120mm fans it would be able to cool well though im not sure how great this case is.
Any Advice would be great, thanks.
I've heard that it is a good case, plus there's the all black interior version on ocuk, which is a bonus. Personally I've never been a fan of the aesthetics of this case, but each to their own. There are some nice cases around for under £100.
Lian Li PC-60FW
Coolermaster HAF 922
Lian Li PC-7F
Lancool PC-K62
Coolermaster Storm Scout
I think all of the above are nice cases and you should definetely check them out before you make your decision.
