good cpu cooler
19 Feb 2008
Home
hi,does anyone know a good cpu cooler to get ?
i have a p190 case and a ds3 mobo with a conroe 2.4ghz cpu.
im after a cooler that bolts on to the mobo as i dont like the clip ones as my freezer pro wasnt all that good for clips.
many thanks....mark
The tuniq towe is a beast keeps my E2160 clocked to 3GHzat 41 degrees running othos.
I thought fitting it was going to be a nightmare but with the motherboard out it is quite straightforward.
keeps temps down and is not too noisy
thanks very much for the reply thefishdude.
i am sure about the tuniqe as it has good reviews.
but will it fit on my ds3 mobo ?
