good cpu cooler..
24 Mar 2010
Looking for a good CPU cooler
Hey.
Currently I have the 1366 Gigabyte X58A UD3R. Case is the ATCS 840.
I originally tried the Titan fenrir but it was to big for the pc due to my memory having large fins and hence the Titan not fitting in. I am stuck on the stock CPU cooler atm and would obviously like to upgrade this.
Id be looking to keep the price around £50 give or take and the only concession would have to be that size wise it cant be to big to not fit into the case and around the memory.
<EDIT>
Just so its clear, Im using this memory:
http://www.overclockers.co.uk/showproduct.php?prodid=MY-008-PA&tool=3
Due to the size of the heat spreaders it seems to limit my options because a lot of air coolers wont be able to clear these memory (exactly why I couldnt use the Fenrir.
Thanks
I know most people seem to suggest the h50 from corsair and that was my first choicest after doing some digging it might not be best considering the negative pressure that happens inside the atcs 840.
It would mean having to change a lot of the other fans on the case which I'm not really in a position to do. Not easy trying to find a good cooler that won't get in the way of the memory.
