12 Oct 2008 at 23:16 #1 Kerplunk Kerplunk Soldato Joined 10 Jan 2006 Posts 9,432 Location Bournemouth tbh Has anyone got a good CPU reader gadget that I can add on? I have Windows Vista Home, Thanks
12 Oct 2008 at 23:17 #2 AntiHeroUK AntiHeroUK Associate Joined 25 Mar 2008 Posts 784 Location Northern Ireland Do you mean a gadget that will tell your your clock speed or temperatures or something else?
12 Oct 2008 at 23:20 #3 Kerplunk Kerplunk Soldato OP Joined 10 Jan 2006 Posts 9,432 Location Bournemouth tbh Yes please, all of the above if possible
12 Oct 2008 at 23:25 #4 AntiHeroUK AntiHeroUK Associate Joined 25 Mar 2008 Posts 784 Location Northern Ireland Take a look here and see if there is anything that meets your requirements.
12 Oct 2008 at 23:26 #5 Kerplunk Kerplunk Soldato OP Joined 10 Jan 2006 Posts 9,432 Location Bournemouth tbh Thanks matey!
12 Oct 2008 at 23:28 #6 AntiHeroUK AntiHeroUK Associate Joined 25 Mar 2008 Posts 784 Location Northern Ireland Np. Hopefully one or more of those will do the job for you. If not there are plenty of sidebar gadget sites to be found on google
12 Oct 2008 at 23:30 #7 Final8y Final8y Soldato Joined 7 May 2006 Posts 12,183 Location London, Ealing The best http://www.thehobbylounge.com/forum/
12 Oct 2008 at 23:36 #8 lsg1r lsg1r Soldato Joined 25 Jan 2007 Posts 4,823 Location King's Lynn Final8y said: The best http://www.thehobbylounge.com/forum/ Click to expand... what he said, and I would probably say thats the best place for most sidebar addons really. I think all but one of mine are from there
12 Oct 2008 at 23:47 #9 Kerplunk Kerplunk Soldato OP Joined 10 Jan 2006 Posts 9,432 Location Bournemouth tbh Final8y said: The best http://www.thehobbylounge.com/forum/ Click to expand... How do you get names, like CPU, RAM used etc... I can add the numbers part, but the name is just blank?
13 Oct 2008 at 00:34 #10 helmutcheese helmutcheese Permabanned Joined 19 Jun 2007 Posts 10,717 Location InURmama Use the older ones, I do not like or use the new ones where you need config them yourself. http://forums.overclockers.co.uk/sh...3&highlight=hobbylounge+username_helmutcheese
