Another shout for the Recon. Being able to control the fans through software or a smartphone/tablet is probably one of my most used features on it.
The system is under a desk out of the way, So the touch screen is a bit awkward to access and then if I'm in a game, I have to minimise it to change fan speeds.Why would you want to do that if your sitting next to the machine?
http://www.lamptron.com/product/controllers/fc9/
200watts over 4 channels and no irritating LCD displays or fiddly controls.
Doesn't support PWM fans though, the recon does. (Think the recon comes in PWM and non PWM configurations)
Ive got the Recon but i never use the LCD. Download Phoebetria is superb software to control it. can create customer temperature profiles![]()
