Good fans for Corsair Hydro H110
12 Dec 2009
Gloucester, UK
Hey guys,
I'm getting the Hydro H110 for my new rig, just wanted to know if swapping the stock fans for a pair of Noctua NF-P14s REDUX PWM 1500RPM 140mm, is a bad idea or good?
If it's bad, what fans would people suggest. Sorry if this is a noobie question.
I believe there are no SP140's
They were supposedly announced/revealed at Computex 2014.
TechPowerUp! said:
Air Series LED SP120 and LED SP140 High-Performance Edition Static Pressure Case Fans
The visually striking Air Series SP120 LED and SP140 LED fans incorporate the award-winning design of Corsair's SP series fans - a design that utilizes seven ultra-wide, custom-molded blades to deliver higher static pressure for radiators and heat sinks, resulting in superior cooling efficiency. Rubber mounts and highly reliable hydraulic bearings deliver outstanding cooling with exceptionally low vibration, noise, and turbulence. These new LED fans are available in 120 mm and 140 mm sizes with red, white, blue, green, or purple LED lighting which illuminate the clear-frosted blades with four vivid LEDs.
  • MSRP: $12.99 single pack / $23.99 double pack
  • Size: 120 mm x 25 mm
  • Operating Voltage: 7-12V
  • Airflow: 57.24 CFM
  • Static Pressure: 1.6 mm/H20
  • RPM: 1550
  • Sound level: 26.4 dBA
  • Connector: 3-pin
Air Series SP140 LED
  • MSRP: $15.99 single pack / $29.99 double pack
  • Size: 140 mm x 25 mm
  • Airflow: 49.49 CFM
  • Static Pressure: 1.17 mm/H20
  • RPM: 1440
  • Sound level: 29.3 dBA
  • Connector: 3-pin
Source - http://www.techpowerup.com/201497/corsair-unveils-the-hydro-series-hg10-gpu-cooling-bracket
I'm assuming there will be a non-LED variant of the SP140's. OP I'd either wait for these or go with some Akasa Apaches or may Noctuas (IndustrialPPC range if you're feeling extravagant!)
