Good fans?
14 Oct 2012
Hi,
I'm looking at getting a few fans.
I'm looking to fill up the two front slots (120mm) and the top two (120 or 140mm)
I already have a back exhaust, but no intake. Any fans you recommend and what slots would you recommend I fill up (two intakes at the front and 1 exhaust at the top?)
I'm looking at Arctic F12 Case Fan - 120mm for the front intake.
Corsair AF120's are fantastic.
Silence over performance?
I kind of want a good balance - i'll be willing to substitute performance for a more silent one.
The current temperature is ok in my system, GPU is a little high but i've bought a special GPU fan for that.
Other recommendations, however I am no fan expert.
YOUR BASKET
3 x Noctua NF-F12 PWM 120mm Focused Flow PWM Cooling Fan £15.98 (£47.94)
3 x Scythe Gentle Typhoon 120mm 1850 RPM - 3 Pin £14.98 (£44.94)
3 x Be Quiet! Shadow Wings Fan Mid-Speed - 120mm £12.98 (£38.94)
Total : £141.73 (includes shipping : £8.25).
BeQuiet fans are great for silence and very good performance.
I believe the Noctua's are some of the best all-rounders.
E; Misread the OP and thought you only wanted to fill one slot, add an extra to each of the above.
Scythe gentle typhoons, i bought some for my new WC rig and they are without a doubt the best fans i have ever used and I have used everything from antec to zalman if you take my meaning :) , plus if your feeling adventurous you can take them to bits and spray them any colour you like :)
i have a corsair sp120 at the front and its quiet and sucks air in pretty good,also swapping the heatsink fan for an akasa venom viper pwm coolfan plus 2 80mm arctic f8's , just awaiting delivery...
