Good, Free DBMS solution
13 Jun 2009
My own head
I have a customer with little or no money who wants a DBMS developed... I'm thinking of doing it with open source software to keep the costs to a minimum, and to prove something to myself.
The client has no licenses for Microsoft Access as far as I'm aware so I would need a full solution (possibly web based) to update and manage the DB.
So yeah, what DBMS would you guys recommend?
Main uses will be:
Maintaining bookings
Maintaining venues
Keeping track of availability
Queries
Go go team OCUK. This will be my first commercial DB, fun times. Although I have had training in DB development / management etc.
Yup, XE is your best bet, assuming the database will be small enough to run within XE's hardware limitations.
Cheers for the suggestion guys, will take a look into it. Will it require a dedicated box to be running the oracle server? Or can it be ran from a single clients machine, so self contained database as it were?
You're looking at like maximum of 4 simultaneous clients if it was server based, thats at a push as the team is quite small, it would expand if we made the database into something for the entire department, but that is way past my six month contract here so would get complex.
It runs as a service on any machine, I run it on a P4 & Core2Duo at work with no issues. XE Supports a max of 4gb of data I think, this will last a long time with just text however clob/blobs will soon eat it up:)
Is there no way to plug the APEX system into a longer term database? 4GB will indeed hold a lot of data, but any overheads are bad overheads considering I'm the only expertise in the team to be able to do this, needs to stand on its own, if they use the DB day in / day out and eventually run out of space, they will be stuffed.
It's 11gb nordays :)
"The maximum amount of user data in an Oracle Database XE database cannot exceed 11 gigabytes."
robotCocks mySQL doesnt come with a front end tho (I may be wrong :o))?
heh Sorry robotCocks,
I use Oracle at work and find XE really usefully for testing hence why I suggested it :) I have only used mySQL with custom front ends :)
Any above "basic" web hosting is going to provide you with and SQL database and access via phpmyadmin allowing you to have both web hosting and complete control over an open source database.
Although from the fairly straight forward requirements I'd be looking at a Wordpress installation with a couple of plugins such as http://wordpress.org/extend/plugins/webreserv-embedded-booking-calendar/. Unless you looking to specifically develop it from scratch for the challenge/fun of it. Which is fair enough.
Web hosts are not an issue, this is for a large organisation with a few hundred employees :D. I only started a few weeks ago, and learnt they have NO database to store their information and do enquiries, it's all paper / spreadsheets which made me laugh.
I did have a crack at installing oracle XE last night with the APEX ui, needless to say "more reading required", definitely not a plug and play solution! I will have another crack at it later in the week.
php + mysql + linux on a vm would be a good way as it leaves room to grow.
I had never used any of it but there is lots of good info on net so I could get it up and running.
I have to say that for small deployments, why not use mysql as it will likely give you everything you need but unlike Oracle XE you will be able to install it on bigger better servers without paying if it needs beefier hardware at some point.
Or have I misunderstood something here?
MySQL doesn't have a user interface?
