- 7 Sep 2020
What I currently have is AOC q3279VWFD8, the budget 32'' IPS.
It isn't the worst for prolonged text work (it does have a blue-light filter and optional low brightness setting), but it isn't ideal. Can't even really say why, as IPS is not necessary text-unfriendly, nor is 32'' necessarily too big, although 27'' might be more manageable without having to turn your head or zoom, or whatever.
I thought I could buy an additional monitor just for text work, which case 24'' @ 1080p would be sufficient, the focus being on whatever the monitor's manafucturer does to protect your eyes and avoid problems due to seeing so much black text on white or similar backgrounds all the time.
Alternatively, I could just upgrade my main monitor if there existed a good VA or PVA option that wouldn't end up worse for gaming than my existing screen (1440p @ 144 Hz wouldn't really be necessary as my CPU + GPU aren't strong enough for that kind of thing and I probably won't be upgrading them to that level).
So perhaps the better course would be to buy a used monitor just for text work if there exists something that stands out as specifically good for long hours of pure text work. More than 24'' and 1080p wouldn't be necessary, but I wouldn't like to go below, either (resolution more so than size).
Any suggestions?
Any suggestions?
