man sick of all the crap and wires that come with these cheapo lights
i have a tidy case and not much room behind the mobo for all this lot. anyone recommend me a good set of white/yellow lights that dont come with all the cables, power packs, power spliters and switches.
NZXT are bringing out a 5.25" bay RGB LED solution soon that allows youto select the exact colour you want. You can already buy something without the front panel that uses an infra red remote to dial the colour you want. A bit cheaper too.
12v LED strip/tape is an excellent DIY solution if you have access to a soldering iron and have an (single) ounce of soldering talent!
No need for transformers etc, can run directly from 12v molex, much easier to hide and is self adhesive. LED colours are far superior to CC tubes, reds especially
