Good PSU for office pc
9 Feb 2004
wales
Hi there
I’m doing a budget office build.
Ryzen 5500g
ASUS PRIME A520M-K
16 gig ddr4 3200
I need a decent low power PSU, can someone recommend one. Need it to be very quiet and £60 max.
I’ve been looking at the Corsair cx550, is this one good enough in terms of quality?
Thanks
Also have a look at the msi mag at £49.99
(need to translate)
IV-Conclusion:
MAG
A550BN has good voltage qualities. Component quality is quite good, Maximum operating efficiency reaches 89.31@230VAC meeting 80Plus Bronze standard, PSU operates smoothly. and is only really noisy when the ambient temperature is hot enough. Equipped with a black fiber cable system to help increase the aesthetics of wiring in the case, the
A550BN is the choice for mid-range computer (PC) configurations used. 1 VGA with capacity under 200W
Advantages:
-High efficiency 89.31@230VAC, 80Plus Bronze
-Good Ripple noise
-Quiet operation
-VRM(DC to DC)
Disadvantages:
-Need to improve Hold up time.
